Anyone with 33's & 4.88 gearing?
I was going to wait until Superior begins shipping their 4.56 gear set, but what the heck! maybe I'll do it now and go 4.88's in my 6 speed two-door.
Anyone with this set-up? Any regrets?
Thanks in advance!
Thanks in advance!
It doesn't look too bad... I put together a calculator to play 'what if' with different gearing, tire sizes, etc. (see below)
Still, I'd really like the benefit of someone else's experience!
I've got a 4 door standard and am running 33's with 4:88's.
I went from 3:21s to 4:88's.
I went this route because I plan on getting 35's at some point in time and didn't want to regear again.
Wheelin' it is awesome...I have a lot more low end tourque...
Gas mileage isn't as bad as I thought it would be...I am getting 15 mpg around town and 14 on the highway. But, the max I feel comfortable cruising at is 75 which is about 3100 rpms.
I've had this set up for about 3 months now and traveled about 5000 miles. I've taken it out on 2 8+ hour trips on the highway.
Hope this helps...
Hope this helps...
In addition to my JK I have a TJ. My TJ is currently set up with 4.88s and 33s. I hate driving the TJ on the freeway. It screams and reminds me everytime that it is time to get the 35s put on. I would highly recommend not doing it.
no high speed jeep for me
If you need to run 70+ mph in a Wrangler and DD it on the freeways, I'd keep the gearing low(4.56:1 tops w/33's). If you don't mind driving a little slower on the freeway and want a little more power to the wheels for wheel'n, go w/4.88's. Or, if you're like me and your Jeep is not a DD (my DD is a Peterbilt) or you dont care how slow you go on the freeway and want exelent power transfer to the wheels go w/5.13's.........just stay in the right lane on the freeways or you might get run over.
In my case, when I can get the $ together for mods I'll be running 35's and a minimum of 5.13 or 5.38 gearing. Maybe higher.
p.s. Those of you that really use your off-road tires off-road alot. Carefull with the speed, OK. I'd hate to find out anyone on here killed their Jeep or themselves and or a family member because a steer tire blew apart doing 80+ mph and they high speed rolled it.
