Is anybody running a Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit ???
#22
Not to be a jerk but throwing $1200-$2,500 (Redneck Ram / PSC) not including labor depending on your mechanical skill set isn't something that you simply consider. Not to mention that adding hydro assist isn't a cure all. I agree it takes the load off the box and the drag link but what about the track bar and wheel? Its certainly worth considering if your building towards 40's down the road.
#23
dde02dde02dde02 Not to be a jerk but throwing $1200-$2,500 (Redneck Ram / PSC) not including labor depending on your mechanical skill set isn't something that you simply consider. Not to mention that adding hydro assist isn't a cure all. I agree it takes the load off the box and the drag link but what about the track bar and wheel? Its certainly worth considering if your building towards 40's down the road.
#25
As far as welding the mount, it is two basic chunks of cheap shit construction grade steel plate. Mig them on at a buddies house if you don't weld. It takes about an hour, it's not brain surgery.... it's gluing some metal to your Jeep.
#26
I'm sure that most of the forum members do not have the same access to the space, tools and materials that some of you do. Also to state it's as simple as welding to pieces of metal together and call good isn't a fair assessment. Clearly you have an above average mechanical knowledge, skill and access to tools then the majority of the forum members. Your set up looks clean and well built thanks for sharing the pics.
#27
#28
You don't believe that there's a fair learning curve when building to 37's? I have benefitted greatly by having friends who can weld which has helped me build my axle to run 37's with peace of mind. There's nothing wrong with wanting to learn, I believe that to often people just slap parts on their rig without understanding the ripple affect they have. In this case the OP is seeking info on the brace, someone stated hydro assist should be considered. Which is a viable consideration but there's quite a bit more work involved when compared to the brace. To often on this forum people state things but fail to elaborate further which leads to misinformation.
#29
Don't get me wrong, I'm not saying Hydro assist doesn't have it's place. It does, but that place, is not on every single Jeep.
I'm going to break the internet here, I run 37's, I don't have hydro assist, I don't have 1 ton axles and it's been this way for 5 years. Let me guess, "it's a ticking time bomb," or "I'm going to be the one that breaks and ruins everyones day," lets see, what other BS can you spit at me? "See you at the mall." LOL!
All I'm saying is share your knowledge, cause somewhere in there you do say some logical stuff, but don't be so damn condesending and realize not everyone is heading to KOH this year.
I see your point. Be mindful that in this scenario you now have 4000#'s plus on your one tire, something will move. I've seen a lot of parts break because hydro assist gives you no 'feeling,' if the tires stuck hard enough, something is going to give. It may not be the sector shaft, now it's the knuckle, control arm mount, etc.
