Is anybody running a Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit ???
Metal cloak works with the synergy stuff. That being said, if you are running a MC lift, your bigger issue is going to be the coils rubbing the brace when compressed. They don't play nice. I've heard of people clearancing the brace to make it work. My AEV coils rub it a little, and I'm switching to MC coils in a week. I plan to ditch the brace altogether.
It not only depends on the coil diameter but if your axle is moved forward with CA's.
I run the brace but not the support. No room if i wanted to.
Depending on lift height has anybody tried running a stock Tb With SYNERGY's sector support? Just curious.
Synergy
I ran the sector shaft brace and trac bar bracket with my MC GC Lite 3.5. MC trac bar fit fine. Coils rubbed a bit. I ground down the bracket some and all was well.
I have this selector shaft brace and run a RK track bar no problem. Took it to MOAB for EJS and ran all week without issues. I have the 2 and a half inch RK lift and moved away from the RSP selector shaft brace because I hated taking it off to check the torque specs.
