Anybody got OME long travel kit installed on JK?
Old 05-07-2010, 07:18 AM
wolfmanii's Avatar
Default Anybody got OME long travel kit installed on JK?
If you have OME long travel kit installed on your JK, could you please tell me
1. What are the good things this kit provide
2. What are the weak ares this kit need to improve.
3. List other parts needed, (such as drive shaft, ball joint...), in priority order.
Thanks
Old 05-07-2010, 07:26 AM
wazooz2424's Avatar
used the search and found this....
http://project-jk.com/jeep-jk-write-...ation-write-up
Old 05-07-2010, 07:27 AM
JK-Forum Founder
wayoflife's Avatar
Thanks
1. it offers an outstanding ride and provides a lot of flex on the trail
2. if you get the +40 coils, they'll give you a 4" of lift and at that height, you really want some kind of track bar and drag link correction up front and track bar drop in the rear.
3. if you have a 2-door, you really should get a new u-joint style drive shaft and adjustable upper rear control arms so that you can set your pinion angle. if you have an automatic, you'll want to replace your front shaft as well - it's not critical but, you will tear off your boot the first time out.
Old 05-07-2010, 07:52 AM
JK-Forum Founder
wayoflife's Avatar
Originally Posted by 69spike
I agree with wayoflife! I don't have anything negative to say about mine. Get the kit from Dave and Northridge4x4 and you will get everything you need. He is very helpful and will make sure you get what you need! Here is what mine looks like before and after!
super nice looking rig ya got there
Old 05-07-2010, 10:08 AM
wolfmanii's Avatar
OME long travel kit has two options: HD and LD
My JK is 4 door, has heavy offroad bumper front and rear, will have a 10000 lb winch
pretty soon. besides that, my JK is stock.
My questions is:
what actual lift will the HD set make for my JK
what actual lift will the LD set make for my JK
Old 05-07-2010, 10:12 AM
JK-Forum Founder
wayoflife's Avatar
My questions is:
the LD coils will yield a little more than 2" of lift. the HD coils will give you a bit more than 3".
Old 05-07-2010, 10:14 AM
JK-Tex's Avatar
I'm installing LD coils this weekend and plan to take before/after measurements. Will post precise results on Sunday.
Old 05-07-2010, 10:19 AM
roadking54's Avatar
My questions is:
I'm pretty sure the OME LT kit from Northridge only comes with HD coils....I will soon know for sure on the height, but Dave said around 3 1/4" on an unlimited.
Old 05-07-2010, 10:21 AM
JK-Tex's Avatar
Dave can get whichever coils (LD or HD) you want. Ask me how I know!
Old 05-07-2010, 10:24 AM
Bowman's Avatar
You need at least 3 inches of lift for the long travel shocks.
Quick Reply: Anybody got OME long travel kit installed on JK?
