Any tips to getting more flex from a 2" OME lift?
Old 10-11-2012 | 03:25 PM
Northridge4x4's Avatar
Sponsoring Vendor
The only way really to get more flex would be to change the shocks out.
David
Old 10-11-2012 | 04:18 PM
Zombie Hunter's Avatar
JKU with OME LT articulating - YouTube
Old 10-11-2012 | 04:29 PM
LOST's Avatar
OME HD 2.5 lift with stock shocks disconnected front sway bar.
Same lift with OME long travel shocks from Northridge. It's difficult to lift a tire off the ground with the LT shocks.
Old 10-11-2012 | 04:51 PM
JohnnyQuik's Avatar
David
This. With longer shocks, sway bar disco's, and extended brake lines, you'll flex until your springs pop out.
Old 10-11-2012 | 06:58 PM
Rob50lx's Avatar
Another possible option is to add shock extensions to the front shocks and raise the rear lower shock mounts. These things will increase travel as long as your bump stops are set appropriately to protect your shocks from bottoming out. Another benefit of raising the rear shock mount is that you have better protection for the shock and increased clearance if you trim off the old mount.
Rob
Sent from my HTC Glacier using Tapatalk 2
Old 10-11-2012 | 07:29 PM
backcountryislife's Avatar
David
I know I'm the one asking the question & not claiming to be an expert... but I'm not at full extension on the shocks, I'm currently limited by the swaybar links... not the shocks, so right now, changing out the shocks would do exactly NOTHING.
What I'm looking to do is get TO the point where the shocks are the limiting factor, and decide if I am satisfied with that.
I'm a metal stud framing project manager, making some brake line drop brackets is a piece of cake, I've got some 16 ga metal & a chop saw in my shed... gravy. but I wanted to see if there was a better way to go about it... I've heard some say that's a poor way to do it, looks like you can get lines for the rear on fleabay for $90 that are intended for a 4" lift... thinking that's "better", but I can make a bracket for free & see where I can get to for free.
Lost, so to get to that point, you just pulled what slack you could get, no extensions up front?
That's basically what I'm trying to figure out. The rear obviously needs extension or relocation, but I don't want to drop it a few inches, disconnect, and think I'm fine, then rip out a brake line.
I get how the front works, but when disconnected, the links stop me quite a ways from full extension of the shocks up front. (rear shocks are about 1-1.5 from extension in rear like I mentioned)
Rob, got a link for the extensions you mention?
