Any tips on aligning front LCA's with stock mounts?
Good Evening,
Swapping out my coil springs and adding some adjustable front LCA's this evening. . .
Any tips on getting the bolt holes to line up? Had to pull in the axle to get the stock uppers to align and now are pulling out the axle for the lowers (pulling towards the front of the vehicle) with ratchet straps.
Using two floor jacks to adjust driver/passenger side axle height. .. . Can't seem to get the axle pulled towards the front enough to get the bottom bolt to line up? Is removing the front track bar critical? Have sway bars, shocks and tires removed.
Any feedback would be greatly appreciated for tomorrow's attempt!
I use a ratchet strap too on the ground, around the axle and to my front bumper rings. If you have tow hooks that would work, otherwise the swaybar. No need at all to remove your track bar.
Here is a link to the write up.....It uses the floor jack positioned into either at the axle or control arm brackets to help you get the arms in...
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Last edited by scooby snacks; 02-15-2013 at 06:05 PM. Reason: removed external link to non-sponsor
Thanks for the input and the link. I was assuming that it would be easier to hit that magic alignment spot with tires off and everything in the air.
Appreciate everyone sharing their experience. .. less cussing tomorrow!
Ratchet straps ftw deff helped me out A LOT. Also once I was able to grt the bolt started through a lil persuasion with a hammer, don't kill the bolt but nice gentile hits, helped, me out.
