Any solid 4" Lift Kits under 1K?
Just saw the thread on the Rancho's, looks like a great deal! Looks like I will go with either these or the Pro Comp 4" lift.
Hopefully I can get them before the rebate expires! =P
Cool! How long have you had them? This ProComp kit is what shop had suggested, so I just came on here to do a little research.
How does the ride compare to stock? Would you purchase these again? Did you have to do any other mods (driveshafts, etc)?
Also, what tires are you running with this kit?
Is this absolutely essential? I was hoping the 4" lift wouldn't need this.
I'm new to all this, so I'm not too sure what the benefit of this is. I do know that a re-gear will be in order, hopefully sometime in June.
I wheeled with a crew called desert wranglers up in Vegas where I bought the thing 45 days ago and they all run the procomp stuff and I never heard any of them complain about the stuff.
Kyle, do you have any side pics of your rig you'd be willing to share? You have pretty much what I want, the Pro Comp 4" and 35" KM2s (although I'm looking at 17s)! Would be awesome to take a look!
BTW, how much total lift do you get with the lift and KM2s? Just want to make sure I clear my garage! LOL!
I installed the Rough Country 4" lift 2 months ago. The X-flex arms are well designed and super strong. Unlike most other brands, R.C. includes 4 shocks and comes with a no questions asked lifetime warranty. The ride, both on road and off, is smooth and controlled; better than stock.
http://www.roughcountry.com/jeep_jk_...lift_kits.html
Several venders here sell R.C. below list.
The steeper angles from the lift will 'pinch' the little rubber boot in the joint, which will eventually wear through it. When that happens, it starts spitting grease, which you will see sprayed in an arc on the undercarriage above the joint. When it loses enough grease, it will dry out, make some noise, and then seize. These driveshafts are not serviceable, so you will want to replace it before it seizes. (people are losing gears and tcases, even catching on fire from seized shafts)
Anyway, make a habit of crawling underneath and looking.
