Any rubicon owners use these?
Old 09-05-2015 | 04:20 PM
  #21
lulu2533's Avatar
Originally Posted by drexelsteve
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=623864"/>
You sure? They look pretty much identical to the JKS quicker discos I have installed on my jeep. The pic just doesn't show the mounting pins.
They do look the same, however they are two different products per the jks website.
Old 09-05-2015 | 04:27 PM
  #22
lulu2533's Avatar
Originally Posted by jeepmojo
however it seems that it might as well be quick diso though and then just dont pull the pin , then you have tat option over no pin design . ive also wondered about these
however at the time some one said its just throwing money away (same as stock )
but it looks stronger and you can grease them plus pull the pin if need be
but i too have the button i push . lol and agree less i have to get out and do the better i like it ! but i figured if the e disco motor went these would still work no?
Yeah. The quick discos would seem to be a wiser choice I guess. They are only like 50 bucks more. I'm just having a hard time with this whole edisco thing. It sounds like no matter what links I get and whatever length I set them to, it will be better to manually disconnect anyway...ugh.
Old 09-05-2015 | 04:30 PM
  #23
buckeyedolfan's Avatar
I did this to my Rubicon sway bars for more flex and since putting on my lift the E-discos are not reliable......at all. And I am afraid on the E-disco flip that happens. And yes I have extended sway bars on the front and they are parallel to the frame.
$8 total for disconnects.
Old 09-05-2015 | 04:37 PM
  #24
drexelsteve's Avatar
Originally Posted by buckeyedolfan
I did this to my Rubicon sway bars for more flex and since putting on my lift the E-discos are not reliable......at all. And I am afraid on the E-disco flip that happens. And yes I have extended sway bars on the front and they are parallel to the frame. $8 total for disconnects.
they should be around 3-5 degrees higher than parallel to the frame to prevent inverting them.
Old 09-05-2015 | 05:29 PM
  #25
JK08MCS's Avatar
Being mine was an 08, I had problems with my e Dico engaging back after offroading. I'm lazy as all get out, so I got this from Offroad Evo and enjoy the desert driving alot more sense I can disengage in 4 high or 2 high by just a turn of the knob. Just a 3 bolt install. Click image for larger version
Name:	Evo 1087 NoLimits Manual Rubicon Swaybar Disconnect.jpg
ID:	623867 Click image for larger version
ID:	623868 And I don't remember having to pay that much for it
Old 09-05-2015 | 05:38 PM
  #26
Krawlersaur's Avatar
https://www.jk-forum.com/forums/jk-o...-319427/page2/
Bottom of page 2. I had mine set at 13 degrees. Still popped the sway bar backwards. This happened today.
Old 09-05-2015 | 08:09 PM
  #27
Originally Posted by Krawlersaur
https://www.jk-forum.com/forums/jk-o...-319427/page2/ Bottom of page 2. I had mine set at 13 degrees. Still popped the sway bar backwards. This happened today.
too much travel in your shocks and not using limiting straps. Neither the shocks or the sway bar links should be the limiting factor in your suspension. You did it wrong. Your links were still set wrong.
Old 09-05-2015 | 08:45 PM
  #28
jeepmojo's Avatar
Default i dont know
but u know the ol sayin if it aint broke dont fix it lol
my e disco works fine as is why tamper with it , is my feeling now
my jeep is almost 4 years old now no prob with disconnecting soo
maybe just put that 160 .00 into gas tank or something that is needed to
when it breaks ! unless you know its gonna be better
Old 09-05-2015 | 08:53 PM
  #29
jeepmojo's Avatar
Default that looks good right there
Originally Posted by JK08MCS
Being mine was an 08, I had problems with my e Dico engaging back after offroading. I'm lazy as all get out, so I got this from Offroad Evo and enjoy the desert driving alot more sense I can disengage in 4 high or 2 high by just a turn of the knob. Just a 3 bolt install. Attachment 623867 Attachment 623868 And I don't remember having to pay that much for it
who manufactures this item ? And can you over ride it if its not turned in , when you just hit e disco ? or do you have to turn it each time regardless of situation?
Old 09-05-2015 | 11:33 PM
  #30
Links were maxed out. After that there isn't anything you can do. And for the limiting straps, why? My springs don't unseat. And every stock jeep and 95% of wheeled ones never run them.
