Any rubicon owners use these?
#21
They do look the same, however they are two different products per the jks website.
#22
however it seems that it might as well be quick diso though and then just dont pull the pin , then you have tat option over no pin design . ive also wondered about these
however at the time some one said its just throwing money away (same as stock )
but it looks stronger and you can grease them plus pull the pin if need be
but i too have the button i push . lol and agree less i have to get out and do the better i like it ! but i figured if the e disco motor went these would still work no?
#23
I did this to my Rubicon sway bars for more flex and since putting on my lift the E-discos are not reliable......at all. And I am afraid on the E-disco flip that happens. And yes I have extended sway bars on the front and they are parallel to the frame.
$8 total for disconnects.
#24
I did this to my Rubicon sway bars for more flex and since putting on my lift the E-discos are not reliable......at all. And I am afraid on the E-disco flip that happens. And yes I have extended sway bars on the front and they are parallel to the frame. $8 total for disconnects.
#25
Being mine was an 08, I had problems with my e Dico engaging back after offroading. I'm lazy as all get out, so I got this from Offroad Evo and enjoy the desert driving alot more sense I can disengage in 4 high or 2 high by just a turn of the knob. Just a 3 bolt install. And I don't remember having to pay that much for it
#26
Bottom of page 2. I had mine set at 13 degrees. Still popped the sway bar backwards. This happened today.
#27
https://www.jk-forum.com/forums/jk-o...-319427/page2/ Bottom of page 2. I had mine set at 13 degrees. Still popped the sway bar backwards. This happened today.
#28
i dont know
but u know the ol sayin if it aint broke dont fix it lol
my e disco works fine as is why tamper with it , is my feeling now
my jeep is almost 4 years old now no prob with disconnecting soo
maybe just put that 160 .00 into gas tank or something that is needed to
when it breaks ! unless you know its gonna be better
#29
that looks good right there
Being mine was an 08, I had problems with my e Dico engaging back after offroading. I'm lazy as all get out, so I got this from Offroad Evo and enjoy the desert driving alot more sense I can disengage in 4 high or 2 high by just a turn of the knob. Just a 3 bolt install. Attachment 623867 Attachment 623868 And I don't remember having to pay that much for it
who manufactures this item ? And can you over ride it if its not turned in , when you just hit e disco ? or do you have to turn it each time regardless of situation?
#30
Links were maxed out. After that there isn't anything you can do. And for the limiting straps, why? My springs don't unseat. And every stock jeep and 95% of wheeled ones never run them.
