Any issues with parking decks and 2.5 lifts/33s
Old 11-11-2009, 03:18 AM
Flyingbrian's Avatar
Great Question!! my garage is 7' and i have 33's on 15" with a leveling kit( 2' front 1" rear) and I still have 3 to 4 inches with the hard top. the soft top has a little more lift with the support bar over the front buckets.
I want to do the 2.5 TF but I'm really liking my level kit.
Old 11-11-2009, 03:25 AM
Suffolk JK's Avatar
With 3.25" TF up front and 2.5" TF in the rear on 35s, no issues on parking decks. Sometimes I hit the CB antenna, about it.
Old 11-11-2009, 11:06 AM
bigbellyfoo's Avatar
Sweetness. Thanks for all of the replies! Maybe I should go a little higher!
Old 11-11-2009, 11:30 AM
roadking54's Avatar
Building codes vary by state and obviously when the structure was constructed. Any specific new garage height bldg code will obviously not apply to any existing structures.
I live in Seattle and there are many garages in existing towers that are well under 7'.
The garage where I'm currently parking, won't be after lift, is at 6'5". I've even seen a 6'0" restriction in an older tower downtown.
However, a new condo tower i was in that was just built downtown is over 8' I believe.
It's all over the map.....personally, I'm going to get the lift and tire size I want and then relocate garages when necessary
Old 11-11-2009, 11:44 AM
schulje's Avatar
I work in Baltimore, MD and have to park in a garage and my 3inch Teraflex and 35's cause the plastic pipe that's marked 6'4" clearance drag across my hardtop. Once past that I clear the ceiling and pipes but are some low bulk head locations I have to avoid.
Old 11-11-2009, 11:50 AM
PaulW's Avatar
I've never had a problem in NJ but I only have 32s with a 1 inch spacer lift.
Old 11-11-2009, 11:57 AM
HG07JKRubi's Avatar
I have that setup...2.5" TF coils and 33's and I'm at 6'5".
Old 11-11-2009, 07:04 PM
w00dchuck's Avatar
Don't forget about speedbumps... Some parking structures have added them after they passed code.
Quick Reply: Any issues with parking decks and 2.5 lifts/33s
