Anti-seize lub on back-side of wheel spacers?
Putting wheel spacers on this week and wondered if putting a thin layer of anti-seize lub is recommended or not necessary. Just want to do it the best way possibe.
Thanks
Thanks
saw some much older posts that said they used it to keep them easy to remove if necessary, would like to know for sure otherwise I will skip it
I just took some spidertrax off that had been on for about a year. Had to use a large screwdrivewr to get them loose. Maybe antiseize would have saved some time??
I would absolutely use the neverseize. The spacers are aluminum and the rotors are cast, add the two together and give them some moisture, road salt, and time and they will be a corroded mess. I neverseized mine and have pulled one back off, just wiped the neverseize off and recoated before reinstallation.
There are certain things I'm glad there is some level of connection with - the hubs and the spacers are clearly one of them, I'm not planning on removing my spacers even semi-regularly, no need to - that's why we use red loctite not the blue - more permanent.
Quit being so OCD and leave them alone.
If the manufacturer of my Spidertrax had wanted never-seize in there I think they would have suggested it or included it like they did the red-loctite.
I'm not sure if they are anymore good with the indents from the screwdriver on the back side
