another way to remove front axle??
i know there is a write up to remove front axle on the jk. i have used it to remove mine. is there another way to remove front axle without having to disassemble entire wheel assembly? my father says the older trucks and such, you could do something like pivot the axle up or down, remove the ujoint and slide the axle out. is this possible , is it too much trouble if possible, or should you just stick with removing wheel assembly and sliding it through? this is just curiousity. he just doesnt believe thats the only way to do it. any comments appreciated. if it cannot be done or is not recomended, i would appreciate the reason why, not just a no it cant be done answer.
Do you know how much trouble it would be do disassemble a u-joint still attached at the stub shaft? What's so hard about removing the 5 wheel studs, 1 axle nut, and 3 hub bolts?
those with kids or have parents like this im sure u understand where i am coming from.
I can't imagine taking out a press-fit u-joint while still installed on the vehicle.
appreciate the responses, maybe he will think diferent once he sees the photos.
You have to remove the hub/wheel bearing to get the axle shaft out, You can now tell your pop that an ASE certified master tech with 20 yrs experiance told you that this is the only way to do it. I argue with my dad over pluming crap all the time.
