Another Vibration Issue
I know there are many threads about vibrations out there but I cannot find what I am looking for. I have an 13 JK, 3.5" lift, 33" tires, aftermarket drive shafts. About a week ago I ran it in 4 hi due to ice and snow, when I put it back in 2 wheel drive I picked up a vibration. The vibration has now continued whether in 4 or 2 wheel drive. It also only does it when you are under power or decelerating. Meaning that when you first let off the gas it goes away to resume when the engine RPMS drop low enough to start slowing the jeep. Also if you shift into neutral it goes away. I have found that my axle seals are leaking and plan to replace them this weekend but did not know if this would cause a vibration. Also the fact that it goes away when there is no resistance on the drivetrain has me stumped. Anyone have any ideas.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
Worn mounts possibly? Leaky axle seal not going to have any bearing on vibration.
I'm only thinking from a logical standpoint, that the issue didn't seem to start until you had it in 4WD....at which point you would have had extra tension in the system, then after shifting back to 2WD, vibs there regardless of 2WD or 4WD. Also, when letting off the gas or shifting to neutral it goes away....times when there is less stress. Although I've never had a warped axle, I 1) can't imagine that just spontaneously happening, and 2) would think main effect of that would be way out of spec camber than driveline vibes. I'm lead to believe vibes are originating from tranny/TC, not the axle.
Axle seals do wear from time to time. I've had to randomly fix on my '13....in fact, noticed the other day I have one right now to address.
Vibration under load and under coast points to a ujoint problem. Ujoints in aftermarket shafts are typically greasable and if you haven't don't that, they may be toast.
I have checked and greased them, don't see any visible play. I did have to replace one about a month ago but have not had any issues till this popped up.
