Another Teraflex BB question
Fallen Hero
I did the TF BB and it lifts the jeep up 2-1/2" front and rear. If you had a sag before you will still have it. I ended up pulling out the front spacers and getting 3" HD front springs. I have a winch and bumper on the front and it still sits about 3/4" low. You'd probably be level without the winch and bumper weight with new springs.
For the money that you would spend on those spacers you could damn near get some nice wheels. Go for the wheels, you know you want to.
I have 4.5" backspacing on my Eagle Alloys, 33" x 11.5" tires.......
I have no rubbing even with no lift.....
your lift
I have an 07 Sahara 2dr and I too did not want to have the factory rake and I wanted to keep the jk level. i am happy I went with the TF BB because I went camping and put a rack in the hitch with a cooler, tent, and a garden hose reel and it leveled out real easym otherwise it would look like crap if I did otherwise. As for the spacers do it, you will not be disapointed on its handeling, and you will rub in 2 different locations on your rig and the rule is for every inch you go up you are supposed to go half inch out to be stable. I put the spacer on because I am not planning on changing my oem wheels but if your are not you don't have to get the spacers just get at least a 4 1/2 backspacing on your aftermarket wheels.
Fallen Hero
Go look at any tire in a 33x12.5x18 then go look at the same tire in a 33x12.5x16.
Get as much flex as you can on one side at a time to gain enough room to install the springs without a coil compressor. A pry bar is your friend. When installing the springs, set the bump stops inside the springs prior to spring placement. Then, once the springs are seated, use a pry-bar through the coils to seat the bump stops into position by prying upwards. It's tricky, but eventually the bump stops will "pop" into place.
When droping your axels, watch the ABS wires. Pull them loose from the clips, then don't forget to reinstall them. Just don't streach those wires....
Oh ya,,, No beer till after your done......
