Another steering floaty and loose thread
#21
Glad it was just the stabilizer needing adjusting. Here's the thing about stabilizers.....they're really the final piece of the puzzle in keeping the system in harmony. You don't have to have one. Many people don't use one (I'm one of those people). Using gas charged units in that application is not the best. Ideally you have a SS that has generally equal resistance both extending and compressing whereas a gas charged unit is always trying to expand with significant force. The way that is counted is using 2 gas charged units facing opposite directions, and doubling the ridiculousness IMO It's been a long time since I had a factory DL mount. If you ditched the double SS set up and just put something like a simple TF 9550 VSS or even a factory SS back on, I'm pretty sure you'd have no clearance issues. It would be more simple than dealing with the DL; however, you're forming the common opinion of RC lifts as you can see.
^^This indeed seems very common.
rock7174 (01-04-2019)
#22
I have the exact same rough country lift and tire set up as you. My steering felt the exact same way. It was loose and the steering seemed to wander all over the place on the freeway. I replaced the balljoints with Teraflex HD ones, HD track bar, rubicon express steering stabilizer and HD tie rods. The toe was off quite a bit as well. After recently getting an alignment it now rides like a totally different Jeep and I mean in a good way. My experience w the rough country lift had been good so far. It's not stiff and actually comfortable. On the trails it's does pretty well. My Jeep is an 08 so it rode like a 10 year old Jeep all loose and stuff. Now I actually enjoy driving it.
#23
Update: Stabilizer is the issue. I took it off and it road pretty good. Before taking it off I measured the difference in each stabilizer to make sure that it was getting the full range of motion for left and right steering and it was quite a bit off. I never did re-adjust it after getting an alignment. Put it back on and dialed it in and it steers like it should. One thing though. The drag link hits on the right stabilizer on tight turns.
