Another Rattle Question
I have a 2010 JKU Rubi auto with a 2.5" OME HD lift, 35's, a JCR front bumper and RR rear bumper with a tire carrier. I recently picked up a rattle coming from underneath after an off road trip. I have spent a lot of time on my back under it shaking parts, checking bolts and beating on things to try and figure out what the hell is rattling to no avail. I don't see any obvious signs of wear from something being loose. It makes the noise every time I go over the smallest bump, even the seams and cracks in the asphalt, I can't tell if it's coming from the front or rear. It's not a real heavy sound like something significant banging around and I can't feel anything transferring to the steering wheel or brakes.
I have looked at everything I can think of under that damn thing and still can't figure it out, do any of you have any suggestions? I've searched the threads and tried the suggestions there. I don't want to just turn up the radio and ignore it.
My 2012 did this last week ended up being that the upper sway bar link bolt was just barely loose on the pass side. But it was enough that it was allowing the sway bar to slide up and down on the bolt making a clunk sound over every little crack in the road.
I've checked all of the main suspension components and can't seem to find anything with play in it that seems abnormal.
It's not the skids or exhaust crossover. I have a Durango I drive for work and it has 85k on it and it recently started making the same noise, it sounds like crap. I noticed on the Durango that it stops if I'm on the brakes while going over a bump, can the shoes get loose in there? Maybe that's what I need to look at on the JK, I'll have to take the front wheels off and check it out.
Should there be any type of slack where the shoes sit in the caliper?
I took the front wheels off and everything is tight and looks okay, except for the groove I have on the back side of the drivers side brake rotor. The pads still look like they are in good shape but there is a groove right in the center on the back side, I'm assuming I have a rock caught in there, they don't squeel or anything when I brake.
I think the tie rod is the culprit, I know it moves but when you push it or rotate it down hard it makes that same kind of hollow tin sound, so I'm thinking that when I drive it rotates down to that position and just sits there and rattles. There is no slack in it left to right just front to back. The steering arm roatates also but it doesn't clank when rotated all the way like the tie rod. Any idea how tough they are to replace or if I should just get a needle tip and grease the crap out of the joint? I wouldn't think they would be that tough to replace but I've never done it before. Any other thoughts on this culprit?
I also have the same lift and also had a rattle. After "much" time underneath it turned out to be the bolt that holds the drivers side bumpstop had somehow was gone. The bolt is probably sitting on a trail in Colorado. It was not until i pushed on the bumpstop did i realize it was freefloating in the spring.
