Another broken axle...
Old 02-19-2008, 01:31 PM
jeepguru's Avatar
Originally Posted by 2K1TJ
Dang, you guys are scaring me!!
>>>>>>digging in couch cusions for change to add to my D44 swap jar<<<<<<<<
Why it wouldn't help any to have had a D44. The ujoint is exactly the same.
Old 02-19-2008, 01:52 PM
pulman01's Avatar
I think superior has the D44 chromoly axle shafts with full circle clips. If mine goes, then I will prob go this route.
Old 02-19-2008, 02:02 PM
wayland1985's Avatar
I'm curious about the tire size as well. I was hoping to get the mopar rubi axles on mine too...
Old 02-19-2008, 02:30 PM
PhirstJeep's Avatar
Default Here's my recently blown axle shaft assembly
Here's my recently blown Dana 30 front axle shaft
running 33"s on 17s
Old 02-19-2008, 04:10 PM
2K1TJ's Avatar
Not the one I'm saving for! ChroMo's, baby!!!
Old 02-19-2008, 05:25 PM
muddpuppy01's Avatar
Mine ticks when I out it in 4wd but its the driver side from what I can tell. I have not even played with it. Everything I lock it in for is just to make it easier to get thru not that it was needed ie new construction sites.
Old 02-19-2008, 05:46 PM
GatorGreenJK's Avatar
Default Here is my carnage
The recovery was nasty. My frinds TJ and his warn winch were pretty stressed.
front passenger side u-joint exploded while climbing a technical section off-road. I heard the POP! and then the clicking and the snaping and the noises you do not want to hear going uphill with no hope of getting out in 2wd, even backwards! I actually destroyed mt rear tire carrier trying to get out of this mess in 2wd. never give up...
Old 02-19-2008, 07:32 PM
CIJeep's Avatar
You guys that had this problem, did they replace the wheel bearings too?
This looks like some nasty stuff, one more reason to lift the axle off the ground and do your "shake" tests, and visually check the U-Joint caps as was suggested by a couple people.
Old 02-19-2008, 07:36 PM
08 rubi's Avatar
i broke my left front axle 2 monhs ago and they repalced only the axle and upper and lower ball joints in my rubicon
Old 02-20-2008, 06:06 AM
jkkat's Avatar
As far as mine is conserned, I was pulling and tree backwards in 4Lo with lockers on and spinning on rocks BUT it was covered under warranty.
Quick Reply: Another broken axle...
