Another 15" wheel question......
I've read everything that I could find in here about 15" wheels but thought I'd check to see if anyone is running the Pro Comp Series 152 Street Lock 15x8 w/ 3.75 BS. I saw where usmcdoc14 is running a 15x8 with the same back spacing without problem (btw - I plan on doing the same lift and tires as you - yours looks great!). I'd really like to get some input from you all before I place my order. Also, what are your thoughts on Mickey Thompson Baja Claw Radials?
they are just regular "D" windows with a decorative outer ring, the mounting area is exactly the same as the "normal" ones. So yes they will fit
I have had no problems with the claws, they are an OK coprimise in needs. Just be careful in snow/ice unless you sipe them but this is pretty much the same for most MT's . I should be sipeing mine in a week or so and will post up a how to for those wondering WTF that is
