Am I sagging too much?
Minus my Synergy products on the front end, the kit is one whole kit from Zone that the previous owner put in. I don't believe there is anything limiting the coils per say since I can fully stuff the tire and drop the opposite end without any binding or issue. I have RC front lower CA's and the axle is centered with the JKS adj bar. The rest would be stock arms though. Thanks for the picture, I'll post my measurements when I get home.
hah and so the truth be known.. yeh common issues, we are left to "clean up" others mistakes.. happens all the time.. So yeah as mentioned above.. new coils would offer a bit more resistance and you'd get to keep you factory spacers. Unless you'd actually want to incorp new coil spacers also..
The mfg told you buy adjustable spacers instead of warrantying/replacing their coils that had sagged. Mighty nice of them.
The ACOS have minimum lift heights involved. 1" minimum for the front, 2" minimum for the rear. Probably not the route you want to take.
I think the axle centering comment was front to back (control arms), not side to side (trackbars). Along with some type of coil correction, might be something to consider if you choose to stay at your current height.
The axle centering front to back 'should' be good. I had a shop give me a print out of where I stood after I replaced the front end stuff and they said the numbers were good. I think they called it the thrust angle? I still have the print out in the garage so I can post the results on that one.
Say, do you flex allot.. or have quick dicso?.. i didn't notice if you did.. Even if you line these back up and without anchoring them down.. it will happen again.. In many cases it's prob best to start with a clean slate.. this way you know what you're getting and getting into.
Here is the thread the measurement pictures above were taken from: https://www.jk-forum.com/forums/stoc...ements-297499/
With all of the factory spring part numbers I'd bet they're all pretty close. The only way to get correct caster numbers from the factory is to get the suspension height set to spec. Although I do know the quality on Jeeps isn't exactly excellent.
