Aluminum Diff Cover??
I have G/2 diff covers which are made out of aluminum. While they might not be as strong as ductile iron covers like ARB, they are still plenty strong for trail riding and much better then the factory stamp steel covers. The aluminum should also dissipate heat better then the iron covers. Now, if you're into heavy rock crawling, I would go with an iron cover.
But with which brand cover you choose, go with some Lube Locker gaskets [rubber coated metal] instead of the rtv seal. Lube Lockers already has sealant applied and the gaskets are reusable.
I was hoping someone on here was running these. Nice to hear you've had no problems with yours.
Thanks
