Allignment. What do I tell the shop?
Ok so I finally got the kit installed and I am taking it over to get an alignment and I wanted to check if you guys had input on what numbers I should give the alignment shop.
I got a 3inch lift out of the kit and I have 35" tires on a 2 door X.
From my research it should look like this:
Castor: 5-6 degrees through shortening upper controll arms 3/8 of an inch
Toe In : 1/8 of an inch closer than stock
Is there anything else I need to tell them?
don't tell them to shorten anything until they have done the measurements. Let them review with you the adjustment needed. try to gt 4.5 to 5.5 degree caster.
do you have 8 new arms or did you only get the uppers?
toe should be 1/8' in or neutral. I run neutral but next alignment I'm running 1/8" in.
EDIT: Check out this thread..... https://www.jk-forum.com/forums/modified-jk-tech-2/cam-bolt-77765/
If you do go to an alignment shop, make sure it comes with a warrenty. I paid $129 for a 5 year warrenty. Have been back there 3 times due to bent tie rod, adjustment to my suspention, and change of tires. Worth the money.
