All will be okay with this right?
I've got an 08 unlimited sahara. Im moving up to a 4 inch lift. I'm gonna go with the super lift, 1.5 inch spacers, and 35's on my stock rims. This should work out fine right?
JK-Forum Founder
sure, it'll work out but "fine" is subjective and not something i would agree with. 4" is a lot of lift and in my opinion, more than you need for just 35" tires. in my opinion, 3" is a better fit and, even at that, i would at least recommend the addition of adjustable front lower control arms so that you can set your caster. also, assuming you have an automatic, you will want to install a new u-joint style front drive shaft. the factory one is too wide in diameter and will catch your tranny pan damaging the boot and eventually cause your tranny to leak.
