Alingnment help??
Old 10-03-2013, 04:50 AM
Mark Doiron's Avatar
So if I'm following this right, what is there to pay a shop to align?
Old 10-03-2013, 05:06 AM
jk.bushwacker's Avatar
well the JK only needs a front end alignment so $30-$60 is reasonable but you could pay up to $100. kinda pricey but labor rates vary from shop to shop. the JKs are simple compared to most cars of today and honestly unless you know your toe is out for sure and are too lazy (like me) to be bothered with tenths of an inch, then you prob don't need to take it to a shop because the other adj will be more personal preference on a lifted rig and if they try to adj caster, camber etc to stock specs you prob wont like the out come on that lifted rig
Old 10-03-2013, 05:15 AM
kjeeper10's Avatar
Only toe and steering is adjustable stock. Some guys like to get a base caster number. Use that to adjust your arms.
Old 10-03-2013, 05:41 AM
Bonedoc's Avatar
Originally Posted by kjeeper10
That much lift you are prob not going to get a good caster angle, even stock the pinion angle is going to be extreme. Why so much lift ?
Generally you are shooting for
4.5* caster
1/16-1/8 toe IN
camber under 1* (not adjustable)
Thrust angle should be correct if the rear axle is centered and square with the frame.
*All 8 CA's.. You want your axles centered in the wheel wells. Rear pinion 1-2* below the DS.
If you settle for just uppers for the rear you can set pinion only.
*Front uppers or lowers can be used for caster. Uppers shortened or lowers lengthened.
X2 on this, I've read that it is better to use adjustable front lowers to set your caster, not sure why, just something I've read. You definitely want to get some adjustable rear in there with that much height as you are creating some significant geometry changes there as well.
Another consideration with that much lift would be a draglink flip kit. I just swapped out my 4.5' trailmaster kit for a 5.5' Rock Krawler lift. Huge difference in the handling with the draglink flip. If I had known it would be so much better I would of installed one when I had my 4.5' kit.
Old 10-03-2013, 09:19 AM
Well, that's why I'm trying to figure out exactly what he has. I must apologize for not knowing intimately what parts go into the making of every lift kit out there. Some come with adjustable control arms, some do not. Some trackbars, front/rear/both. Some even have new driveshafts. But, the way I am reading this, which may be a misreading on my part, the OP has brackets and stock LCAs (when OP posted a picture of the brackets, he seemed to agree with someone else who posted saying specifically that he does). Maybe we should digress and ask OP to clarify:
Exactly what lift did you get? What suspension components did you replace? What about trackbars? If you just lifted your vehicle, using control arm repositioning brackets, and didn't replace the trackbars, I return to my prior question: Exactly what are you expecting an alignment shop to align? You have the steering wheel centering, and you have the toe in (which shouldn't have changed). They can give you numbers for everything else, which you may or may not find useful in the future, but there's nothing they can align (Again: Say no if they offer camber bolts). Honest, once you really start fixing your Jeep for 4.5" of lift (control arms, trackbars, driveshafts), those numbers won't be worth a hill of beans. Really, you'll have to come up with your own numbers, because there are just too many variables for an alignment shop to understand, short of a competent 4WD shop that understands custom suspensions.
Old 10-03-2013, 09:20 AM
Originally Posted by Bonedoc
... I've read that it is better to use adjustable front lowers to set your caster ..
The only reason I know is they have a wider adjustment range. They are certainly more expensive. Perhaps a secondary reason is to get a better built (tougher) component down there where it's exposed to possible damage from contact with a rock. The uppers are pretty protected.
Old 10-04-2013, 01:50 AM
kjeeper10's Avatar
Well, that's why I'm trying to figure out exactly what he has. I must apologize for not knowing intimately what parts go into the making of every lift kit out there. Some come with adjustable control arms, some do not. Some trackbars, front/rear/both. Some even have new driveshafts. But, the way I am reading this, which may be a misreading on my part, the OP has brackets and stock LCAs (when OP posted a picture of the brackets, he seemed to agree with someone else who posted saying specifically that he does). Maybe we should digress and ask OP to clarify: Exactly what lift did you get? What suspension components did you replace? What about trackbars? If you just lifted your vehicle, using control arm repositioning brackets, and didn't replace the trackbars, I return to my prior question: Exactly what are you expecting an alignment shop to align? You have the steering wheel centering, and you have the toe in (which shouldn't have changed). They can give you numbers for everything else, which you may or may not find useful in the future, but there's nothing they can align (Again: Say no if they offer camber bolts). Honest, once you really start fixing your Jeep for 4.5" of lift (control arms, trackbars, driveshafts), those numbers won't be worth a hill of beans. Really, you'll have to come up with your own numbers, because there are just too many variables for an alignment shop to understand, short of a competent 4WD shop that understands custom suspensions.
That person was me. Control arm drop brackets do wonders for drivability. (Leaving off road out of it) and put caster back into stock range. Nothing to adjust and the stock bushings are better then some aftermarket bushings out there. Caster in check, toe in 1/8 and steering centered is about it. Pretty easy to do yourself.
Next I would be looking at correcting steering geometry in the 4" range. Before installing me Synergy flip kit the steering wheel would jerk back and forth over every bump.
I see it a lot ... "4" lift for only $500"
Anybody can throw 4" coils in a kit. Maybe bumpstops/sway bar links and most likely cam bolts for caster. Lifting a Jk over 3" introduces a slew of problems if not set up correctly IMO.
There's also comes a point where it's impossible to run stock caster and have decent drivability
Try lifting the jeep 4" (5" front and 4" rear typically) and run 5* caster. The pinion angle becomes just too much for the DS Cv Joint to handle. Some folks have no choice but to give up caster for pinion angle.. Especially if the front DS was replaced.
ID:	502488   Click image for larger version
Quick Reply: Alingnment help??
