Is alignment needed after installing BB and disconnects
Have a 2010 Sahara JK that I want to put a 2inch BB on and install disconnects for the same amount of lift. Will a wheel alignment have to be done. Thanks for all the great info on this site. Great stuff for a newby
Drive it afterwards and check it out, usually the wheel will be off center but you may not notice any difference in the way it drives. If you can live with the steering wheel like that then nope!
Loosen two bolts, turn the turnbuckle until the steering wheel is straight, tighten bolts. One person, less than 5 minutes.
This is in the write-ups area (there is an index at the top)
http://project-jk.com/jeep-jk-write-...-end-alignment
There is no need for you to have an alignment done unless you remove the front track bar. centering your steering wheel is easy, but may take a few times until you get it right. Good luck and have fun with it!
