Alignment issues
No the two charts they gave me were from when I brought it after the CA install. First one is what they said my jeep was at, second one was after they made adjustments.
Looks ok what tires do you have ? Some will cause a radial pull.
Its normal to have .2-.3 difference side to side. The stock axle has some cross caster built in. After installing my arms i was at 3.5 and 3.8 iirc. After turned both uppers in one turn to raise it a bit. No pulling issues or vibes.
Looks ok what tires do you have ? Some will cause a radial pull. Its normal to have .2-.3 difference side to side. The stock axle has some cross caster built in. After installing my arms i was at 3.5 and 3.8 iirc. After turned both uppers in one turn to raise it a bit. No pulling issues or vibes.
Yeah, I don't get this, but mine has a difference of 0.5* between sides with the passenger being less castor. It's enough that I have to have the control arm on the passenger side out one half turn further than driver side.
