Alignment ?
Old 10-23-2008 | 07:17 AM
JUS 1 MO's Avatar
Default Alignment ?
I finished my lift (Teraflex 2.5 BB) and tire/wheel (ProComp 17X8/Nitto TG 295/70R17) project. It drives and handles great, no pulling one way or the other, just like it did before. My question is: Should i have to have the alignment checked when the vehicle drives fine?
Thanks...
Old 10-23-2008 | 07:21 AM
bly109's Avatar
nope... just make sure your steering wheel is centered and you should be fine.
RedneckJeep's Avatar
No. You should not. I would keep an eye on tire wear though, just to be on the safe side.
Old 10-23-2008 | 08:13 AM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
Originally Posted by JUS 1 MO
... Should i have to have the alignment checked when the vehicle drives fine?...
Unless you've changed some additional parts, there's not an alignment tech can align! Here's a good write-up on doing it yourself (assuming you have changed some suspension parts):
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Quick Reply: Alignment ?
