alignment
Any suggestions on where to get the alignment done with an aftermarket lift? I know some places use manuf specs to reset it and wasnt sure if someone had any ideas on where to go where they can set it to my specified lifts specs. I use Firestone for my wifes and my past rigs but wasnt sure if Jeeps needed more love
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
JK-Forum Founder
unless you have an adjustable front track bar and adjustable front control arms with your 2.5" lift, the only thing you will be paying an alignment shop to do is recenter your steering wheel and you can do that yourself with a 15mm wrench and 3 minutes of your time - seriously.
Straightening the steering wheel is like WOL said, 15mm wrench to loosen both pinch bolts on the steering tie rod, and spin the turnbuckle until the wheel is centered (assuming you parked it with the wheels straight). With a 2.5" lift it should only take 1/2 to 3/4 of a revolution. Then torque those bolts back down tight.
Good luck. If you can do the install yourself then don't pay somebody for these easy steps. If you have problems after these two, then come back here before paying.
JK-Forum Founder
http://project-jk.com/jeep-jk-write-...-end-alignment
no need to pay a shop to do what you can do yourself.
having said that, it sounds to me like you're in need of a bit more positive caster. the write-up above will help you to make this adjustment as well but, you will need to have a set of upper OR lower adjustable control arms to do it. an alignment shop will NOT be able to help you out with this without them either.
Looking at your profile it says you have a 2.5in lift AND a TF leveling kit.
If so, your at 4in or more. Are you still running stock control arms in front? If so, like WOL said you need more positive castor and you'd need adj front lowers( or some uppers can do this aswell) Lowers tend to give you more adjustability though.
Also, center that front trackbar and make sure your torque it to 125 ft lbs with the weight of the jeep on the ground.
Did you just add this lift? The 2.5, added to the leveling kit?, other way around? Put it all on at once?
![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
Yea I added the TF leveling kit after the suspension lift so I suspect that needing adj control arms may be the problem more than needing an alignment. Any suggestions as which to get? I'm at about 3.5" all around with the front sagging from the bumper and winch
Several good companies out there though, I'm sure members and or vendors will respond with their recommendations aswell.
