align shocks and coil springs
Hi,
I have Wrangler JK with diesel engine, 2009. A year ago I bought a steel bumper. This month I decide to exchange my front coil springs because they were too weak and besides the car front was more then 2 inches lower than back. I am going also to exchange rear coul springs for the same +2".
1.May I apply Bilstein HD 0" front and rear shocks ?
2.Are there any other parts which must be also changed to fit 2" lift or for the time being I can leave all other serial parts ?
Darek
Darek
I went with OME 2" spring and shock set with JKS front and rear trackbars, adjustable front and rear swaybar links.
Highly recommend the setup. Ride is good and weight is supported evenly on all 4 corners. Should be perfect for your diesel. Gave me the height as advertised (after settling).
Only thing I might add is adjustable lower front control arms, just to get the suspension tracking perfectly.
Good luck !
Good luck !
