Airraid CAI
Old 09-03-2007, 02:40 PM
Okiejk's Avatar
Default Airraid CAI
I need some help on installation. I read that you can easily break your air flow sensor. Any tips for a safe and easy install? Thanks in advance!
Old 09-03-2007, 03:06 PM
murray8144's Avatar
remove the wire harness from the sensor first, then the sensor will be easier to wiggle out
Old 09-03-2007, 03:07 PM
Black Ruby's Avatar
The Airaid is very easy to install! The only tough part is removing the air sensor. What I did was use a sharp utility knife blade and carefully cut from the outside edge of the rubber tube to the sensor (1 inch or so if I recall correctly). If I ever install the stock intake the cut can easily be repaired or sealed. After cutting the rubber the sensor easily pops out, remember to dampen/lube the sensor before pushing into the new intake.
Old 09-03-2007, 04:28 PM
hemi's Avatar
i just carefully pryed it out pulling with one hand and using a screwdriver as a lever to help pull it out
Old 09-04-2007, 08:28 AM
DeepSky's Avatar
Mine just got delivered to me at work!!!
I wanna install this badboy when I get off at 6 but I"m not sure I'll have enough daylight time. The box says "installs in minutes" but I find that hard to believe.
How long does the install actually take?
Old 09-04-2007, 08:54 AM
talondriver9382's Avatar
Install in 30 min max and thats being very careful with the sensor....which requires no special tools just gentle elbow grease and sweet talk!
Old 09-04-2007, 09:06 AM
DeepSky's Avatar
Thats what I wanted to hear!
I can't wait to get this sucker in, thanks for the reply!
Old 09-04-2007, 09:45 AM
D'sjk's Avatar
Default Inakes
How have you guys liked your air raid I was thinking about installing the new K&N or AFE intake but am open to any...
What is your gas mil. change
Old 09-04-2007, 09:57 AM
I believe the general concensus is that the gas mileage isn't really changed much, but that you can definitely feel a bit of a HP gain. Mine is getting delivered by the end of the week, and I do plan to track the gas mileage just to see if there's any type of increase.
Old 09-04-2007, 06:07 PM
cormac827's Avatar
i have the air raid and its awesome.....i got about 1mpg more on the highway....i almost crapped my pants when i saw that i got 19.5 mpg on a recent road trip....im used to 17.6-18.5 on long highway trips.
Quick Reply: Airraid CAI
