Air Tank Locations????
I have the Warn Powerplant and am considering adding a tank. Please post pics of locations available to mount tanks and the size tank would be helpful as well.
Thank You
Thank You
Kilby has a 2.5 gallon tank that mounts where your evap canister is (will need to be relocated on a 2 door). I have also seen people modify this and put it into the stock muffler location, and I have also seen it placed into the storage area in the rear (under the door)
My muffler is pretty beat up back there, but that could be my driving
I have my 2.5 gal where the stock muffler was. So far it has escaped without a hit. I thought for sure I wouldve nailed it by now, but it tucks up alot better then the muffler. But I know I'll still hit it eventually, so a river raider skid is on my list.
I know the ones I saw used a custom tank that was between the frame rails, but I have thought about doing this when I get there with the Kilby muffler skid.
Hi! Due to my extremely slow dial-up (no broad-band and refuse to pay extortionist prices for sat) I don't do pics...but I mounted a 20# CO2 tank to the right rear, inboard side of the "roll cage" and it hasn't gotten in way so far. I don't see why an air take couldn't be mounted there as well. I did use wide stainless steel strapping and grade 8.9 hardware to minimize the risks associated with ripping things apart should I get into a MVA. It is a PIA and needes to be pivited down to lower the roof but after it's lowered I can move it back into place. Not sure if this is a viable location for you though. Take care... Mike
