Air Locker vs E Locker
Old 09-18-2013 | 12:03 AM
rpost215's Avatar
Default Air Locker vs E Locker
I am researching which lockers and it comes down to this. The ARB Air Lockers vs the Eaton E Lockers.
From what I understand, the E Lockers offer a less fail points in terms of o-rings, air lines, gaskets and what not that the Air Lockers have.
The engineering operationally looks pretty much the same. One uses air and the other electric/magnetic solenoid.
Anyone have experience with the E Lockers to share and advise?
Old 09-18-2013 | 01:21 AM
LBJEEPER's Avatar
I have an Eaton E-locker in the rear end of my JKU non-Rubi D44 and its served me well to this point. I still have the old style two pinion design and from what I understand they have upgraded the design to a 4 pinion design but seems to be the popular opinion is to run air lockers for over all dependability and what not.
Old 09-18-2013 | 01:23 AM
Scruff's Avatar
I think that only the d30 locker is 4 pin. The d44 is still 2 pin.
Air lockers are all 4 pin and as I understand stronger designed.
Im just putting in air lockers but I am worried about air leaks to
Old 09-18-2013 | 05:35 AM
familytime's Avatar
JK Forum Regional Rep
We run ARB's,if you don't locked them often the o-ring may dry out.We've had them in our '07 since new
Old 09-18-2013 | 06:03 AM
v8zracer260z's Avatar
Veteran: Marine Corp
I run and ARB front locker with no issues at all works great.
Old 09-18-2013 | 06:49 AM
SabrToothSqrl's Avatar
Default e
Electric reduces your points of failure massively.
Old 09-18-2013 | 07:14 AM
JKred's Avatar
See the quote above yours.... While the electic actuation is simpler in total parts, two spider pinions is about half the strength of 4, locked or open. I would not put a locker in my rig that is only marginally stronger than an open factory carrier.
I run an ARB up front. I've blown the air line once but I carry quick connectors. A quick splice of the line and you're back going again. It locks and unlocks in less than a foot. Worth every penny IMO.
