Air Horn
#21
You could try these. Took about two hours to install using a 6" L bracket mounted to existing holes in the bottom of the hood. Needed to line them up, but they slide in right between the alternator and master cylinder.
Setup cost about $40. Wolo horns. Sound lot better / louder than stock. Not as good as I like, but wanted to check out the functionality in colder weather before getting something bigger. Last set I had would freeze up.
