Aftermarket Hoods with Ripp
I just pulled the trigger on a Ripp. I currently have an AEV snorkel and it has to go due to a new fender setup I want to do. So I will have to replace my stock hood too.
My question is, all the aftermarket hoods seem to have vents directly in the path where the Ripp and its air filter will be. I'm worried about corrosion and direct water damage.
Anyone have first hand experience with different hoods and a Ripp? Thanks.
seen a Jk with a RIPP with water damage to the engine because of the vents near the front which stand wide open right above the filter.... the 10A hood and the AEV hood look like trouble.
that said, you could always just block the vents on the hood so that the hood is sealed and still get the look.
Sponsoring Manufacturer
Sealed Air Box for RIPP Supercharged Vehicles
Congratulations on your new RIPP Kit! If you are thinking of running an AEV hood or 10th anniversary, we recommend running a sealed airbox or sealed variant as the supercharger's filter is right out in the open to that hood. This will move the air inlet closer to the headlight in a safer position. Sealed Air Box for RIPP Supercharged Vehicles
-That link mentions 2012+. I have a 2011, will it still work? I would assume so.
-Does it rob any power?
-Do I replace the spark plugs during install? If so, a brand that you suggest?
-I think I might order the headers with resonator today too and just noticed you now sell an exhaust too. What vendor makes this for yall. Is their some sound clips of it?
-I had an MBRP, but ditched it for the Dominion exhaust, b/c I liked the note better. Which is yalls closer to you think?
Our hood doesnt have any vents near the intake and we engineered a channel behind the vents that span the length of our hood to catch water and divert it away from the engine.
