Aftermarket clutch for 12-14 3.6L JK??
I've noticed this a ton! Also have to use the clutch in 4/lo even to move slowly enough sometimes. I need a rubicon transfer case or better gearing (3.21 sucks) My rpms most definitely drop when off gas in 4-lo cruising through some stuff
Oh and edit/ dealer won't cover a clutch anyways- it's wear and tear
It depends on the reasoning for replacement on warranty coverage. While you are correct that the clutch is considered a wear item , mine does not need replace due to wear. The bearing is bad. Additionally my transmission has already been out at 1800 miles to fix another issue so I can argue the damage was caused by improper alignment when reinstalled. (This is actually what I think the problem is.)
I just replaced my clutch in my 2012. After all my research I found the spec stage 2+ is the way to go paired with a national TOB. Even my friend that installed mine at the dealership said the clutch looks and feels like a huge improvement over stock, same with the TOB. This was only a few days ago when I bought the clutch and I called centerforce to ask when their clutch for 2012s was coming out, the guy on the phone made it sound like it would be a while until they distribute them...
For you guys with the squeaky TOBs I would suggest the national bearing. It's like $35 and it's great!
Overall I spent $650 on the clutch and TOB off some good deals on the internet. Not sure how the clutch compares to the new centerforce though because I didn't even know they came out with it already
Sent from my iPad using Tapatalk HD
See if you can get the clutch, pressure plate, TOB and pinion bearing only. Should be about $500. At least that was all I paid for my '07 (but OEM bearings; CF didn't have theirs out ATT).
http://www.amazon.com/gp/aw/d/B003CG...&robot_redir=1
