After Market HD Drag Link
How do you adjust or recenter the steering when using the Heavy Duty after market drag links like Tera Flex etc
Bec Factory OEM drag link has 2 turn buckles bolts to adjust.
I'm not sure about TF drag links, but the Rock Krawler uses Moog tie rod ends on both ends. You can turn the entire middle section (between the tie rod ends) to shorten or lengthen it. (I don't have the RK drag link, but have read the install doc and am thinking about upgrading)
Their heavy duty tie rod (on the other hand) uses two ends that are threaded the same direction, so you have to take it off to adjust the toe in. (I do have the tie rod and speaking of, I think I need to adjust mine a little tomorrow. )
