AEV Wheel Question
AEV Wheel Question
Does anybody know if the AEV Savegre wheels will fit a stock rubicon. Well I have a tera flex spacer leveling kit but that is it.
Yea know about the wheels being made for jeeps but Did not know if they would fit due to back spacing and offset without a lift that stuff still confuses me.
They are made to ONLY fit Jeeps they are hub centered just as the stock wheel. They are now a factory / dealer approved and available wheel. the backspacing is very good on a JK they also fit the Grand Cherokee.
You can use a jk or wk wheel on a jk. The jk wheels has less back spacing so a wider tire fits. If our are running stock or similar sized tires the wk back spacing will keep the wheel in a little closer to the frame, but still not as lose as stock wheels. If I remember correctly, stock 6" back spacing, wk 5 1/4" back spacing, and jk 4.75"
Chances are you will rub a little at full turn. I have yet to see someone have these wheels and not rub without spacers. I know for anything in the 35+ is an issue but I do not know anyone with a smaller tire so depending on what your getting if smaller than a 35 it may work fine. Look around you will find a lot of used AEV wheels for sale because of this
You want to get something with a backspacing of 4.5 to 3.5 with a larger than stock tire so they don't rub.
