View Poll Results: which kit?
AEV 3.5 Premium
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar2-l.gif)
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar2.gif)
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar2-r.gif)
![](https://www.jk-forum.com/forums/clear.gif)
13
26.00%
Rock Kawler 3.5 x factor mid (adding the AEV High Steer)
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar3-l.gif)
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar3.gif)
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar3-r.gif)
24
48.00%
Full Traction 3" Jeep JK Premium Plus 0% Maintenance kit (adding the AEV High Steer)
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar4-l.gif)
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar4.gif)
![](https://www.jk-forum.com/forums/images/jk-forum.com/polls/bar4-r.gif)
13
26.00%
Voters: 50. You may not vote on this poll
AEV vs Rock Kawler vs Full Traction
I have a 2009 4DR Rubicon Auto and my tax return should be here shortly...I am in need of a lift. I would like to go with 35's with the possiblity to throw 37's under it with the addition of flat flares way down the road. My Jeep is my one and only vehicle so I am 90% on road (highway every day for work) and I get off the road only a couple times a year if im lucky (rausch).
I have a Gobi Stealth Recon Rack and plan to add a RR XHD Rear Bumper with tire carrier in time. The front end has a RR XHD bumper with the front skid and will add a winch sometime down the road.
All that being said I have stock gears and know that will change in time (nj gear install prices/rates are just terrible...) as well as the front drive shaft.
I have been searching through old posts and reading up on as much as I can and have it down to 3 kits... AEV 3.5 Premium, Rock Kawler 3.5 x factor mid (adding the AEV High Steer) and Full Traction 3" Jeep JK Premium Plus 0% Maintenance kit (adding the AEV High Steer)
I understand the Jeep will settle and the install height will not last, but that being said I don't want to worry about the suspension sagging with all the weight I will have on the Jeep.
Any opinions and suggestions welcome...
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Former Vendor
Sir
In order to meet your specific needs we can build you a JK 5.5" Mid Arm X Factor System, but with 3.5" coils and disconnects/rearlinks so you get our high steer setup and HD Drag Link all at the 3.5" lift height just like our PRO Aluminum 3.5 " X Factor System gets....
You can order that combination from any of our dealers/wholesalers/ or us. The price would be the same as the 5.5 with no up charge for making it custom to you!
That truely is the best of both worlds. Alot of guys are doing it...
RK
RK
Sir
RK
RK
Former Member
Sir
RK
RK
Thanks,
Bryan
Former Vendor
What we are saying is all the components of the 5.5" X Factor Mid Arm, but at the 3.5" Lift Height! This way you will get the high steer assembly you are looking for all in one nice, simple, package.
Does that make sense?
RK
RK
The Trailmaster 5" lift is a great kit. It includes driveshafts as well which you should consider. I'm running it with 37s, but I know several people running it with 35s.
