AEV tire carrier and stock bumper. Has anyone done this yet?
Here's mine... I re-used the brake light from the factory spare mount as well since the tire carrier provides an accessory mount above the tire. This tire swing is well engineered, rock solid and EASY to operate
I don't see why you couldn't. AEV will tell you they've only tested the OEM plastic bumper with the carrier. The carrier comes with a template for cutting the hole so as long as you get the hole in the right spot on the bumper the carrier and bumper are completely independent of each other. The RR rear bumper is on my short list for an eventual rear bumper replacement.
If the attachment point on the rr bumper is straight, it will interfere. If it's on an angle
Like the oem bumper it will work fine.
If I were to guess most aftermarket bumpers will NOT work with the AEV carrier.
Also here's a straight on shot showing how the carrier is off center.
