AEV rear bumper w tire carrier
Old 08-14-2013 | 02:08 PM
  #21
Razorbak's Avatar
Originally Posted by MtraXX
I have this carrier and 1 piece of advice... MAKE SURE TO GREASE IT FROM DAY 1!!!! I failed to do so and waited until about 6 months which was into the winter. I apparently was too late and over time, the inner shaft seized up against the outer bracket making it impossible to open. I had to take a cutting wheel to the bracket in order to bang the carrier out. I took a metal brush to it, painted it, put it all back together and it opens smoother then before, however I now have a cut from the bottom to the top of the bracket exposing the inner grommets. I'm fine with it though and it makes it easier to grease! lol....
What do you need to grease? And what type to use?
Old 08-14-2013 | 02:34 PM
  #22
MtraXX's Avatar
There is a zerk fitting on the back of the bracket, where the carrier shaft slides into. I use marine grease
Old 08-14-2013 | 02:36 PM
  #23
Razorbak's Avatar
The brass looking fitting?
Old 08-14-2013 | 02:42 PM
  #24
MtraXX's Avatar
Should be stainless but possibly brass. I'll be home in a few mins, will snap a pic
Old 08-14-2013 | 03:20 PM
  #25
MtraXX's Avatar
Here you go... Grease from day 1 and maintain regularly.
ID:	488277   Click image for larger version
ID:	488278   Click image for larger version
Old 08-14-2013 | 03:23 PM
  #26
Razorbak's Avatar
Just grease around the fitting. Mine has brass finish to it.
Old 08-14-2013 | 03:33 PM
  #27
MtraXX's Avatar
Looking at it closely, mine has a brass tone as well.
No, not around the fitting... You need a grease gun to attach to the fitting to fill the bracket tube with grease.
Old 08-14-2013 | 03:37 PM
  #28
Razorbak's Avatar
Gotcha....I see it now. Will be hitting up auotzone tomorrow. Thanks for the help
Old 08-14-2013 | 03:42 PM
  #29
MtraXX's Avatar
No problem.
Old 08-14-2013 | 03:47 PM
  #30
Razorbak's Avatar
Well I just looked at mine and I don't see the place where to grease.
