AEV or RE
AEV or RE
Looking to raise up an 09 Sahara to fit 35 12.50's Have a winch and heavy bumper up front and will also be carrying a 35 spare. Do long highway trips to 4WD areas and carry some camping gear. Jeep is also a daily driver. Have narrowed kit choices to the AEV 3.5" Premium lift or the Rubicon Express 3.5" Super Flex Kit. I know they are both quality companies and pricing is similar. Anybody have any experience with either kit? Will be done professionally, so difficulty is not a factor.
I'm running some OME HD springs fox LT shocks and am happy 2.5" advert 3" actual. Using Currie arms and front trac bar, and some Teraflex parts happy. I just installed a Teraflex frame/trac bar brace and soon to install drag link flip kit happy. If you get into the steering flip kits do some research and you'll find out that one of your listed companies is just reselling a RHD drag link (around $80 from dealership) which is just as weak as LHD ones. Teraflex makes a NEW FORGED drag link very happy, makes the factory one look silly.
And If you plan on doing any off road stay away from cam bolts.
Teraflex makes some really stout stuff. I'd keep researching lift kits and look beyond your selected lifts. my 2 cents.
Both you guys, I am sure, are far more knowledgeable than I will ever be. I originally considered Teraflex, since that is the kit that my dealership uses. But I was turned on to a local 4 x 4 shop that all my new Jeepin friends swear by. He only will do RE lifts that he considers the best. I've checked out the reviews of RE bushings and see the potential results. AEV is owned and designed by an ex Jeep engineer and has taken a different approach to lift needs, which seems reasonable to me ???? See
4wdandsport.com/tech/0909_4wd_2007_jeep_wrangler_jk_buildup/index.html
The OME kit put together by Northridge is also appealing, but I am finding difficulty finding someone to install that kit in the Phoenix area. I am 68 yrs. old and my wrenching days are over. Sounds like I should probably go back to the dealer installed Teraflex??
Last edited by wayoflife; 05-25-2010 at 06:59 AM. Reason: please do not post direct links to non-sponsors
Look into the Teraflex if your dealer installs it. It's odd that they install that lift on the "for sale" jeeps because the MOPAR parts "factory" lift kit is a RE kit, so just odd but not out of the normal that they would use Tera. Your dealer should have no problem installing any good quality lift. I'm pretty sure they would put in the Northridge kits if you ordered one. I really don't think you'll be disappointed with Teraflex. Teraflex is one of the few companies that is starting to offer different control arms for the 2dr's and 4dr's as they are finding out that the same part lengths are not happy on both 2/4 dr JK's. Nothing major but they are fine tuning the lengths. Just make sure you get a very complete kit as once one thing changes it really affects most of the other suspension.
Front lower adj control arms
Rear uppers, using the front lowers and rear uppers keeps the wheel base as long as possible where the reverse front uppers rear lowers would shorten slightly. 8 is great!
Extended sway bar brackets
Stainless steel brake lines, can use bracket extensions but better to install new SS lines.
Front and rear adj trac bars and related brackets
4- shocks appropriate for lift, Tera's are good but you certainly can upgrade to others
Steering stabilizer upgrade
Possible wheel spacers for looks/better clearance or for bigger tires
Extended bumpstops front and rear
Possible steering flip kit
Possible driveshafts
I think that covers it. The more complete the kit the more expensive, but the better it will work and you'll run into fewer/or no problems. And you'll be able to hop into your rig and go for a drive and not have any worries.
Given that your vehicle is a DD so ride quality and handling on the road are probably important to you and your JK has a few extra lbs in the front and back, the AEV kit is a great choice.
It has the added benefit that you keep the OE bushings which are better than anything else out there on the road.
If you don't want to use the front control arm relocation brackets due to 2" of reduced ground clearance then get a set of quality adjustable CAs.
I have the RE 3.5 superflex and love it. I have been all over Colorado and spent a week in Moab last month. No bushing issues (and I check regularly). Great highway ride as well with the OME long travel shocks. Highly recommend it.
SOoooo....I have the AEV 4.5 on my 4door....I've been reading and seeing that more and more people are saying to get the LCA instead of using the stock because ou have to make the bracket hole bigger...well...it's after the fact now. I did a bunch of research on it too. Does this mean I'm going to have problems down the road? or is there a "fix"...or just call up AEV and ask why?
Thanks
Thanks
JK-Forum Founder
Thanks
Thanks
