AEV ProCal Module for Jeep JK’s.
Old 03-31-2012 | 07:55 PM
BoneShkr's Avatar
I like the restore feature....So I can bring my Jp back to the dealer
and not have any issues with whatever I'm doing to the Computer.
Thank You Everyone who added their opinions.
You have my Trust in asking You All, before attempting
to do something I might regret.
Old 03-31-2012 | 08:09 PM
JimG's Avatar
Originally Posted by masterd78
I am running 37's with stock 4.10s and the procal has made it really nice. Shift points corrected, speedo, and lowered the tpms limit. 2 thumbs up!!
Only feature I can't seem to set is the tpms. Before I received my Procal, I first installed new tires/wheels package and a few miles later the "flashing" error light came on for about a min then it stayed solid lit. Checked the manual and indicates something is malfunctioning when it flashes. I tried everything to the lowest threshold and no go so I finally shut it off completely. I strongly believe its a bad sensor/s.
Has anyone else have had the flashing light come on? ..sensors are 433 mhz
Old 03-31-2012 | 08:53 PM
OutlawJoker's Avatar
Does anyone know if there is a programer for the 2011's yet?
Old 03-31-2012 | 08:56 PM
snytribe's Avatar
I got mine through Quadratec and they waved the shipping for being a member. It set the speedometer. Along with the shift points, which made a big difference.
Old 03-31-2012 | 09:07 PM
FrostByte's Avatar
The AEV programmer is the only one that works on 2011s. None of the tuners work - yet.
Old 03-31-2012 | 09:08 PM
kfxbryan's Avatar
You are making me worry now.
Old 03-31-2012 | 09:09 PM
Footbraker's Avatar
Just lifted the 2011 and added 33.5s. Love the pro cal. Speedo is spot on and with it changing the shift points, I really can't tell ive lost any power.
My jeep was re aligned after the lift, so what is the point of hooking up the pro cal for the ESP programming feature? I don't understand that part
Old 03-31-2012 | 10:48 PM
Fiveofun's Avatar
Originally Posted by LiveOn
Prices do not ever change between retailers on AEV products; so $149 is the price everyone is paying. I just purchased the procal module for my 2012 JKU Rubi for my tires but some of the other functions are as follows:
Tire size change - available tire sizes are 24"-54" (speedometer recalibration)
Low pressure sensors - you can set what pressure you want the sensors to go off at, or just turn that feature off
Axle ratio - option between: 3.07, 3.21, 3.55, 3.73, 4.10, 4.56, 4.88, 5.13, 5.38, 5.67
Restore - restore everything back to your stock settings
Options - one touch lane change or daytime running lamps or auto sway bar system
Engine Functions - set pedal, set VIN, clear DTC codes
Runtime Functions - you can set your idle higher when running your winch
Also, once you plug your procal module into a jeep, it will not work on any other jeep.
Hope this helps pal
What is the auto sway bar system?
Old 04-01-2012 | 12:16 AM
LiveOn's Avatar
I just got a chance to test the sway bar feature of the AEV ProCal. Basically if you have a Rubicon with an electronic sway bar motor that works then it's useless.
When you use the ProCal to turn "off" the sway bar it means that it's off - you can't connect or disconnect it - it's basically a boat anchor. If you use the ProCal to turn "on" the sway bar then the sway bar/switch works normally - in 4hi/lo under 18 mph.
I think this feature on the ProCal is if you have a Rubicon and you removed the motor and want to turn off the system, or you have a non-Rubicon and added the motor and want to turn it on. Again, if you already have a Rubicon with a functional electronic sway bar system then this feature is basically useless.
Old 04-01-2012 | 01:20 AM
FlameRedJK's Avatar
I used the AEV ProCal on my 2012 recently and I would say it is a must have!
Used it to adjust for 35s and my spedo is now dead on.
I also dig the day time running lights function.
