AEV ProCal Module for Jeep JK’s.
About the AEV ProCal Module for Jeep JK’s.
I have a '12 JKU. Does anyone have an opinion as
to whether it is a good thing to have or not?
I found it for $149.00 through Advanced Adapters.
Is this a good price?
Originally Posted by k0260
seems the only benefit of the procal, is speedo correction?
Tire size change - available tire sizes are 24"-54" (speedometer recalibration)
Low pressure sensors - you can set what pressure you want the sensors to go off at, or just turn that feature off
Axle ratio - option between: 3.07, 3.21, 3.55, 3.73, 4.10, 4.56, 4.88, 5.13, 5.38, 5.67
Restore - restore everything back to your stock settings
Options - one touch lane change or daytime running lamps or auto sway bar system
Engine Functions - set pedal, set VIN, clear DTC codes
Runtime Functions - you can set your idle higher when running your winch
Also, once you plug your procal module into a jeep, it will not work on any other jeep.
Hope this helps pal
Originally Posted by LiveOn
Prices do not ever change between retailers on AEV products; so $149 is the price everyone is paying. I just purchased the procal module for my 2012 JKU Rubi for my tires but some of the other functions are as follows:
Hope this helps pal
