AEV ProCal module after three tanks of gas
Old 04-16-2012, 05:41 PM
jefemente's Avatar
Originally Posted by will469
Ok so after running a few tanks of gas this is my info on mileage, before Procal i was reading 13.6 mpg 2007 2dr with 35's and running an auto with 410 gears, now i am reading 17.79, my rpm's are at 1950 @ 65mph, the procal has helped a lot, although the mileage isnt great it is better, i also have a drop in k&n filter, the speedo is dead on, my mileage and speedo was checked using a fuel app and a handheld gps "not a stock navi", so i would say it did help out and i am happy with putting out the money for it.
What PSI are you running in the 35's? In my setup tire pressure make a huge difference in MPG.
Jeff
Old 04-16-2012, 07:24 PM
FlameRedJK's Avatar
Yeah, it changed the numbers, not your MPG or performance...it may say 13.6 but, in reality it is somewhere in between those two numbers...Your Jeep's CPU thinks it is running a much smaller tire, same reason why your spedo is off... Wish I spoke propeller head so I could explain it better.
yeah it changed my numbers from 13.6 to 17.79.
Old 04-16-2012, 07:27 PM
hagausaf's Avatar
it recalibrates, not tune. And yes, I am getting 15 mpg after I recalibrated for the 37" KM2's and 5.38 gears. Was getting about 10 mpg prior.
Old 04-16-2012, 07:32 PM
JackDANJK22's Avatar
I plan on just 285/70r17s "32.8" ... Would this be necessary ?
Old 04-16-2012, 07:35 PM
hagausaf's Avatar
prob not worth buying honestly. for anyone with 35" or larger tires then I'd say yes if you own an '11 or newer model
Old 04-16-2012, 07:37 PM
2012 here .... I was guessing I'd be fine ! ... Those tires are just a .5 taller ... Couldn't see much of an issue ... Thanks for the help !
Old 04-16-2012, 07:42 PM
hagausaf's Avatar
esp good with a '12 and 3.73 gears. You can run up to a 35" tire with that ratio without too much worry on the '12's. For just .5" larger tire I'd save the $150 towards other mods.
Old 04-18-2012, 06:17 PM
will469's Avatar
Yeah that makes two of us.
Old 04-18-2012, 06:21 PM
will469's Avatar
Jeff
Tires can run 50lbs i run 35lbs.
Quick Reply: AEV ProCal module after three tanks of gas
