Aev procal module
Aev procal module
Ok hearing this might be a good idea. Just lifted my jeep 3.5 rockKrawler and went from 33 to 35's. Having some issues with traction control and ESP but need to straighten the steering wheel and I am told that wills top it. IS this device something I should look into?
There is a lot written about the AEV ProCal here for sure. It works and it is something to consider.
http://www.aev-conversions.com/products/procal_module/
http://www.4wheeloffroad.com/techart...aev/index.html
The Procal would probably be good for you. You can correct for the tire size change, which will help with the tranny and the ESP. In addition, it has a feature to help re-center the steering wheel. Mine definitely improved the tranny shift point issue by correcting for bigger tires (which also got my speedo correct), and I haven't had the ESP go off on a tight corner since using it.
Do you have the 6-speed or the auto? With an auto it will probably be a good investment, depending on your needs, cause it resets your shift points. I have the 6-speed w/o TPMS and couldn't justify it, however I also got the dealer to recalibrate the speedo free of charge and I re-centered the wheel when I lifted it so I never had esp problems. To try an save some coin I'd check an see if your dealer will recal the speedo for you. I believe there are write up's on here about re-centering your wheel. Not to smash aev but if I was going for a programmer for an auto I'd probably go with a superchips/hypertech (idk who makes em) to get max performance for towing/gas milage/speed ect.
