AEV Pro-Cal Module - defective?
![Question](https://www.jk-forum.com/forums/images/icons/icon5.gif)
So, I set it (for anything) plug it in, and nothin'. No beeps, no change. Can't change anything.
What's more probable, unit is defective OR something's going on with my computer or OBDII port?
Emailed AEV tech support a few weeks ago and no response.
Is there a good way to check if the computer and/or port are working correctly?
Get it used? They are designed to only work with one Jeep. If you got it used, u have to default set the jeep it was linked to, which un-links the procal from the jeep. Then you can use it on another jeep.
You may want to call them. I know with many of these e-mail from the website options there is a lot of stuff that can go wrong and your e-mail or the responses to it never get all the way through.
Well, it wasn't used. BUT maybe I didn't wait long enough. I'll shove it back in there and give it a few minutes. Was kinda my understanding that it wouldn't take more than a few seconds.
I'll see what happens.
Set the DIP switches for what ever program you want to run and read the manual closely. Two times now I've missed a step because of not paying attention and ended up with either nothing or some weirdness in my Jeep. Try a few different programs too, like steering center and throttle control. Easy ones to set up and you can see the results instantly. Good luck.
