View Poll Results: AEX Explained Thread
Good information to Know
30
85.71%
I dont care how it works
5
14.29%
Voters: 35. You may not vote on this poll
AEV Pro Cal Explained
AEV provides an easy quick reference guide on how to set all the DIP switches. For the tire portion your going to have to do a simple subtraction problem to get the value for the tire Measurements. Again it can only calibrate to the closest .25 inch so if your in between that your going to have to round up or down. I also would recommend every oil change to remeasure the diameter of the tires and Recalibrate the ECU.
I have a 2013 and purchased the Procal that is 2013 ready. I'm trying to turn on the Daytime running lights, but can't seem to be able to get it to work. Maybe I'm doing something wrong. I turn the Key to the On position and insert the procal. The horn honks twice and nothing. No lights on. I'm I missing a step here?
You want me to give you the code?
Position the switches in this order.
101010100
Turn the key to the On position if it cranks you turned too far.
Then plug the module in
The horn will sound.
Programming is done
Also make sure you have the 2013 Ready Green sticker on the box.
101010100
Programming is done
