AEV lift 3.5 premium help
Old 05-28-2012 | 07:09 PM
jeepwave's Avatar
Default AEV lift 3.5 premium help
About to have a shop install my 3.5" Aev lift. Any common mistakes/problems I should be looking for?
I trust these guys but I want to make sure I spent my money well!
Thanks guys
Old 05-28-2012 | 11:49 PM
grumpy1's Avatar
the one thing I would watch has to do with drilling out the hole for the high stear part of the kit. If they dont do get it straight you can have a big problem on your hands not to mention that your allinement may never be true. The rest of the kit is pretty simiple and straight forward. Just thought of some thing else to check on and that would be the front break lines. make sure that your tires don't come close to touching them when your wheels are at full turn other wise your tires can snag them and break you hard lines.
Old 05-29-2012 | 04:07 AM
PD2PLA's Avatar
Is this for a 2012 or older one? I have done the lift on my 2011 and its not too bad, i'll send you pics of some of the brackets and the bolts i used to put the brackets together it will save you time . Just send me your email......
Old 05-29-2012 | 04:22 AM
jeepwave's Avatar
It's an 09 but I'd rather have someone else do it
Old 05-29-2012 | 11:34 AM
RubiconGeoff's Avatar
It's a piece of cake to install. I did mine in my garage in an afternoon, but I didn't drill out my knuckles, I installed Reid Racing knuckles that already have the drag link flip tapered in them.
Old 05-29-2012 | 12:41 PM
jeepwave's Avatar
I believe it but I have no experience lol I'd much rather do it myself of I had help but I don't :( its great advice ill take pics for you guys to check it out after give me your 0.2 cents?
Old 05-29-2012 | 01:00 PM
PD2PLA's Avatar
After you have somebody install the lift go drive it make sure everything feels right and there is no death wobble also get the torque specs from somewhere on this forum or from the aev instructions and re check the torque on all your bolts at least 2 to 3 times about every 50 miles or so, my track bar keep getting a little bit loose until after the third time i tightened now its all good. Make sure the route the brake lines right because some people do it differently and then when you disconnect the sway bar to flex if its not done right you will tear one.
AEV is a great lift when you drive it if it doesnt handle as good or better than stock something is wrong!!
Old 05-29-2012 | 09:40 PM
jeepwave's Avatar
Great advice thanks a bunch
Old 05-30-2012 | 07:52 AM
rockkrawler628's Avatar
Make sure the front brake limes are fully extended by cutting off the bracket.
Old 05-30-2012 | 12:24 PM
jeepwave's Avatar
Thanks this is helpful I will make sure I mention this before I drop
It off and take a look when I pick it up!
