AEV Hood vs TMD Hood
Old 08-09-2011, 09:40 AM
  #21
Sponsoring Manufacturer
TeraFlex's Avatar
I'm kinda partial to the TMD hood. FYI Burnsville doesn't make TMD hoods.
  #22
dillUSMC's Avatar
TMD its BADASS
  #23
snowbdr88's Avatar
Originally Posted by fadeout
I just put an AEV on my rig and couldn't be happier, the fit and finish is top quality and I get the added benefit of the heat reduction.
Sent from my TBolt with 4GEEZ!
Where did you get your limb risers?
Old 08-09-2011, 10:18 AM
  #24
Rubichronic's Avatar
ditto?????????
Old 08-09-2011, 10:22 AM
  #25
fadeout's Avatar
Homemade, I pieced them together from hardware and made the brackets. Couldn't justify spending over 60 bucks on ones that looked like they'd snap off anyway. These cost about 27 bucks total.
Old 08-09-2011, 09:18 PM
  #26
how did you attach them to the roof?
Old 08-09-2011, 09:24 PM
  #27
fadeout's Avatar
I have a light bar and just tapped it and screwed two bolts in. I'm sure that it could be done right alongside the inner driver's door frame and the passengers the same way basically without damaging anything and only leaving a small screw visible.
Old 08-09-2011, 09:28 PM
  #28
thanks. i've been on some pretty bushy trails out here and I'm thinking about adding these. Gonna look into it.
Old 08-17-2011, 06:54 PM
  #29
Navyvetnorwich91's Avatar
I can't tell you how sharp that hood looks. I'm getting one and had wondered whether to have it painted to match my factory black or instead to go with something different like flat rattle-can black to stand out from the rest of the body, but after seeing yours I definitely will go with factory match paint. Great rig!
Old 08-17-2011, 07:54 PM
  #30
fadeout's Avatar
Thanks for the compliments! I went through the same exact dilemma and decided on the end that it would look unfinished if I had it sprayed flat black. If anything I might bedline the grille to offset it.
Sent from my Transformer TF101
Quick Reply: AEV Hood vs TMD Hood
