AEV geometry correction brackets?
I would install the lift first. Read your caster numbers and drive it. Do they work ?
Yes. Combat flighty steering by increasing caster and flatten out the arms for Better handling.
Do you wheel ? If clearance is a issue, adjustable lowers might be a better choice.
Now with that being said. If you want a drop bracket... Go with Rancho's version.
These are getting some good reviews. Couple AEV folks choosing the Rancho's over their own.
Compact, 1 piece and mount inside the factory mounts. I ran the AEV's and now the Rancho's
Better bracket IMO
Better bracket IMO
In order to install the bracket on the passenger side you will have to pry away the exhaust Y-pipe. The easiest way to do so is to put the factory scissor jack between the pipe and the frame. The strain on the Y-pipe will stress your exhaust manifold which has the potential to crack. It happened to me. If it happens to you, you will hear a ticking noise from the engine especially when the manifold is still cold.
In the meantime I have installed stainless steel headers and next time I would opt for adjustable LCAs. No hassle with the Y-pipe and more ground clearance.
Better bracket IMO
Better bracket IMO
So i ordered the AEV brackets right before I read your post on here. After I saw your post I did al little more research about the ranchos, and I saw tons of good stuff. I think I'm going to order those instead. Hopefully quadratec won't give me any problems canceling my order.
Hold up and I'll post a link for the Rancho's cheaper.
http://www.streetsideauto.com/p/ranc...FYdQ7AodVB8AJQ
People I know on WF called QT and they price matched the $120
