aev geometry bracket install help
I thought installing the aev geometry correction brackets would be super simple, but i have run into a problem. The driver side bracket is installed no problems. However the passenger side upper control arm bolt will not come out because the exhaust is in the way. The instructions say to "pry" it out of the way, but it will not move enough. I tried to loosen the exhaust flange, but i cant get a solid connection on the bolt head with any of my tools. Maybe I could just cut the bolt out and install a new one in from the opposite side. If i did this what size bolt would i need? Any other better ideas to get this bolt out?
I actually with the help of a friend installed them without cutting the bolt. Used some rachet straps and a pry bar. I'm sure its easier cutting the bolt but we did it at night & nowhere was open to get a replacement bolt.
I wish they made them for the rear too....
